Fusion Manufacture
Turning a spiral on a Tormach lathe?
2 REPLIES 2
JetForMe
245 Views, 2 Replies
I'm working on a small winch drum with a spiral groove to help guide the cable as it winds. It looks something like this:
I have a Tormach Slant PRO 15L lathe, which can do semi-coordinated moves between the spindle and tool, but I'm not sure if between Fusion and the lathe I can cut this part.
I modeled this as a revolved profile, then cut it with a coil. I'm flexible on the exact groove profile; maybe I can get a cutting insert with the right shape.
Any suggestions or advice on how I might accomplish this?
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
2 REPLIES 2
da_fish
in reply to: JetForMe
I would use a round grooving tool and program it with a threading cycle in Fusion.
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
