Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
trigonometry in manufacturing expressions
6 REPLIES 6
prettygoodnotbad
803 Views, 6 Replies
In the manufacturing workspace, for an operation parameter, is it possible to use sin/cos/tan in the expressions dialog box, if I simply input something like sin(15) I get the wrong number it outputs 0.6503 when it should be 0.2588
6 REPLIES 6
Phil.E
in reply to: prettygoodnotbad
Do these instructions help?
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-76272551-3275-46C4-AE4D-10D58B408C20
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
in reply to: Phil.E
Looks like F360 calculates in rad(ians) rather than the more known deg(rees). You'll need to multiply with Pi/180 after the angle:
value = sin[angle*(pi/180)].
I usually test in Excel with sin(30) or cos(60) which both should be 0,5.
Formula: =SIN(30*(PI()/180))
Regards
   Peter
prettygoodnotbad
in reply to: Phil.E
This article seems to be about user parameters within the design workspace. I'm attempting to use trigonometry within the manufacturing workspace. For example, for a contour operation with even step downs selected and a wall taper angle of 5 deg, in the radial stock to leave field I could do something like tan(slopeAngle) * (abs(stockZLow)-maximumStepdown) in order to offset the cut to account for the slope angle.
Hi prettygoodnotbad,
I haven't taken care about the workspace you're working in; I was just looking at the calculation results from sin(x). This reminds me to the rad vs. deg thing.
I have not tried to do this in manufacturing ws honestly. Just tried to figure out why the calcs looks odd.
Regards
   Peter
prettygoodnotbad
@Anonymous thanks, I saw your message only after posting my reply. But you are correct, what worked in the end with your example is (sin(30 * (Math.PI / 180))) * 1in this output the correct value 0.5
So for the forumla in my previous post I can do:
(tan(slopeAngle * (Math.PI / 180))) * (abs(stockZLow) - maximumStepdown)
This outputs the correct axial offset to avoid machining inside the part when using a wall taper angle.
Now I'm just waiting for someone tool tell me there is a box I could have checked that would have done exactly that.
The functions appear to convert to the appropriate internal units if you specify the units. If you want a specific number of degrees, then just suffix with 'deg'. E.g. sin(15 deg), or sin(0.261799 rad)
