Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
This small pocket won't generate a tool path! No matter how large or small of a tool I use... Even...
25 REPLIES 25
Message 1 of 26
FacebookGroupMember
922 Views, 25 Replies
FacebookGroupMember
Even a .001" diameter tool doesn't work!
A 1/8 or 1/16th endmill should easily give me a decent tool path.
What could be wrong?
It generates tool paths for every other section so far, just not this one pocket on both sides..
25 REPLIES 25
Message 2 of 26
FacebookGroupMember
Did you look at the yellow warning signs? They might give a good clue of what is going on.
Message 3 of 26
FacebookGroupMember
Julien Charest-Lacombe it's just saying my stock was too small compared to my model.
It shouldn't stop the tool path generation
Message 4 of 26
FacebookGroupMember
check your heights?
check your heights?
Message 5 of 26
FacebookGroupMember
Tony Boersma yes they are correct.
Like I said, I can select adjacent pockets and it computes instantly.
This particular one.. No go
Message 6 of 26
FacebookGroupMember
z-axis and x-axis face?
Message 7 of 26
FacebookGroupMember
Tony Boersma yes selected correct
Message 8 of 26
FacebookGroupMember
Save, close, reopen?
Message 9 of 26
FacebookGroupMember
Tony Boersma I'll try that
Message 10 of 26
FacebookGroupMember
Stock too small could be indeed the problem. Why would it generate a toolpath to cut air. Make sure there is stock to cut there.
Simplest solution to these kinds of things is to share the project so those trying to help you can see the entire context.
If you cannot share it all, replicate the problem in a simple one that only retains the relevant affected contours and toolpaths.
Message 11 of 26
FacebookGroupMember
Lucian Tomuța I tested it out by machining other features not in the STOCK box.
It generates fine.
It just doesn't do a full cutting simulation without stock in that area
It generates fine.
Message 12 of 26
FacebookGroupMember
Wot kind of led in you use?
Message 13 of 26
FacebookGroupMember
Samuel Lockhart then I would guess there would also have no pass to link somewhere? Did you try a different style of rampe? Maybe zigzag or plunge if it really needs it.
Message 14 of 26
FacebookGroupMember
Lukša Vlašić I even tried with none!
Message 15 of 26
seth.madore
Any chance you can share the file, even if only privately?
Email it to seth dot madore at autodesk dot com
I suspect it may have to do with your lead in settings and/or ramp values.
Seth Madore
Seth Madore
Message 16 of 26
FacebookGroupMember
Autodesk Community
Autodesk Community
Message 17 of 26
FacebookGroupMember
Message 18 of 26
FacebookGroupMember
Message 19 of 26
FacebookGroupMember
Message 20 of 26
FacebookGroupMember
