Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Tapered Slope Ramp
1 REPLY 1
kamil.malec94
378 Views, 1 Reply
Tapered Slope Ramp
Please see attached the F3D file.
I would like my (2) operation - Ramp to output the arcs as G2/G3 movements. Right now, I am getting G1-XY movements no matter what Tolerance / Smoothing I use. Please let me know if there is a way to to lower the amount of code we are getting (HAAS pre-NGC, nominal, not modified). I am happy with the (1) operation, which gives out about 1k lines of code (it is using G3 a lot). The (2) operation is meant to do the final pass along the tapered profile.
I would appreciate your support.
K.
1 REPLY 1
If you are looking for condensed code, the easiest solution would be to use 3D Contour:
File is attached
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
