Please see attached the F3D file.
I would like my (2) operation - Ramp to output the arcs as G2/G3 movements. Right now, I am getting G1-XY movements no matter what Tolerance / Smoothing I use. Please let me know if there is a way to to lower the amount of code we are getting (HAAS pre-NGC, nominal, not modified). I am happy with the (1) operation, which gives out about 1k lines of code (it is using G3 a lot). The (2) operation is meant to do the final pass along the tapered profile.
I would appreciate your support.
K.
If you are looking for condensed code, the easiest solution would be to use 3D Contour:
File is attached
