I'm using Fusion-360 to cut some t-slots in 5-ply 3/4" plywood. I start by 2D profile cutting the 5/16" slot down to the bottom of the t-slot. I did this to remove material for the shaft of the t-slot and to preclear the material since the t-slot tool cannot cut the slot itself - only the bottom. I want to cut the bottom of the t-slot next, but not sure how to proceed. I tried using a 2D slot operation, but I can't seem to make the operation start outside the stock and enter at the proper height to cut the slot.
I know it's not the best tool for the job, but I'm using a Shars HSS 5/15"x21/32"x1754 (# 404-1701). These are normally used for cutting mild steel or aluminum, not wood. It was the only t-slot cutter I could find that match the dimensions I needed for the t-slot.
Any advice would be appreciated.
-Freeman
-Freeman
You should use a 2D Contour the same as you did for the upper slot. Just pick the lower outside edge of the T-Slot.
