Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
surfacing to floor problem
2 REPLIES 2
nocturnalwelding
156 Views, 2 Replies
Hey, everyone
Making some templates and I ran into this problem. I'm trying to surface to the bottom of the slope but can't make it to the bottom
. I'm sure some kind of fillet might have to be made idk. Looking forward to seeing how this can be done. Thank you.
2 REPLIES 2
Hi
You cannot use a Ballnose to get right to the bottom of the slope, its Physically impossible as it has a sharp corner
With a very small Ballnose or a Bullnose tool with a small radius you can get closer and closer but there will always be material left there.
If you model a fillet equal or larger than the corner radius of the tool you are using then it will work.
If you truly want a sharp corner there you can surface the slope with a Square endmill, but this will require very small step-downs and will still leave a poor surface finish
Another option is to use a tapered endmill, but seeing as its an odd angle you wont find an off the shelf cutter to do this
Or you can machine the slope with a 5 axis machine and use the Swarf toolpath.
I'll try a bull nose tomorrow and or the smallest fillet I can get away with.  Really good info and totally appreciate it.😁
