Hi, this is my first post on here.
As you can see, there is a Glitch near the start of the slope passes.
I have tried re-moddeling the Sill in a different way, but the glitch still happens.
Any help would be greatly appreciated.
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
And what exactly is this error that you're referring to?
The sweep is not smooth. I have drawn a red line where the sweep should be the bottom %50 of the sweep is good. The top portion does translate to the manufacturing processes which should be a smooth linear slope. This is the first time this has happened, other sizes and shapes have not had this problem.
