Everything works well until I try to generate a NC program. As soon as I double click on the NC program icon, the entire fusion stops. However my computer is not overloaded, and the only thing I can do is closing fusion from the task manager of windows. I cannot generate G-code anymore...
What can I do ?
Solved by jeff.pek. Go to Solution.
Does every file do this? What happens if you don't use NC Programs and just go the "old fashioned" route and select a Setup and Post Process the selection?
I wonder if this isn't a case of the window being opened offscreen -- where a secondary monitor used to be? Can you use Alt-Space, and see if a little menu pops up, with which you can move it back into view?
Jeff
You are right Jeff Pek : the window is opened off-screen. This problem occur when I disconnect one screen from my computer...
The solution I have is to re-connect the second screen. Usually, when I remove fusion from the second screen (to the first one) before disconnecting the second screen, I don't have this problem.
This bug appears on every file, and it doesn't work if I restore an old file.
