Hi All,
I'm stuck again, hopefully someone can help. I'd like to stop the post processor moving Y when machining a wrap toolpath. It's leaving a slightly wobbly floor which is visable after anodising. I'm using the generic Fanuc post, I've tried the inverse time post which does leave Y on 0 and the finish is great but my machine doesn't support G93, I've set the use DPM to false which gets rid of the G93 but then the feed rates are very slow. Could anyone help with the pp changes to leave Y at 0 on the generic fanuc post or to get the correct feeds with the inverse time without G93?
Thanks in advance,
Sam
