Fusion Manufacture
Stock not centered with latest update
5 REPLIES 5
PetePayne
212 Views, 5 Replies
Good morning! Looks like in the  latest update (today is 9-22-2020)  Fusion looks at the stock center / origin differently.
I even went back a sketched a point in the top-center  of the part to be able to pick it up quickly.
So - Fusion offsets the stock and also when you run a simulation even though I have it set up as a relative size cylinder - it has a square piece of stock in the simulation.
Am I doing something wrong or did I miss something ?
I attached the file .
Thanks for the help!
Pete
5 REPLIES 5
seth.madore
in reply to: PetePayne
For the stock size and shape: You have your Stock Simulation set to "Fast -3 Axis-". Set it to Standard:
 For the center location; I notice that you have Stock mode set to "Relative Sized Cylinder", but you don't have an axis selected. Selecting the OD of the part does snap the point to the middle:
Seth Madore
hooverwelding
I just read in another post that after the update the stock setting in simulate defaults back to "Fast" (3 axis) instead of standard.
 Try that and see if it makes any difference.
 Carl
hooverwelding
And while I was typing......Seth is FAST!!!
seth.madore
in reply to: hooverwelding
Seth Madore
PetePayne
in reply to: seth.madore
Thanks guys !
