Fusion Manufacture
. step file
5 REPLIES 5
443 Views, 5 Replies
. step file
Hello.
I have a.step file downloaded to a radius milling , but in cam I can not activate the radius.
What am I doing wrong?
see attachment
Greetings Peter
5 REPLIES 5
LibertyMachine
When selecting boundaries, you are rather limited to edges of features, not the actual feature itself. If you wouldn't mind sharing the part, I could put together a screencast showing how to select edges on your exact part, rather than an example with one of my own part.
To share: File > Export > Save to local folder. Return to thread and attach the .f3d in your reply.
Now, you could select the actual surface if you were defining the Touch/Avoid field, but that's another topic for another thread or reply
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
in reply to: LibertyMachine
I send you the file.
Gretings Peter van Gool
Verzonden vanuit Mail voor Windows 10
Hello Kudos,
Hereby the file.
please sent next message to vmdmiddelbeers@gmail.com
Greatings,
Peter
LibertyMachine
Here is a screencast. I've profiled the part with and endmill simply to remove stock from the Simulation model. Second tool coming in is the 3mm ball endmill. I use that to 3D surface mill the radius:
 EDIT: For some reason, the forum is not showing any of my screencasts in the library. You will have to click THIS LINK to view it
Seth Madore
Here is the screencast:
Seth Madore
