Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Fusion Manufacture
Spiral BUG?
3 REPLIES 3
HughesTooling
198 Views, 3 Replies
Spiral BUG?
Spiral seems to cut one way only (the wrong way)! Ignores Direction setting, am I missing something?
Mark Hughes
Owner, Hughes Tooling
3 REPLIES 3
Looking closer I see there is a Clockwise option! Interestingly this is ignored if you use concentric circles and the one way\ other way option overrides the clockwise setting.
Mark Hughes
seth.madore
in reply to: HughesTooling
Do you feel that this behavior is incorrect and could use some polish?
Seth Madore
HughesTooling
in reply to: seth.madore
Seems to me like you only need one of the options? I think this has caught me out before, don't use that spiral often but use parallel quite often and expected this to work the same using direction. Probably doesn't help that the clockwise option is not lower down where the other direction options are.
Looking now you have options for direction top and bottom with this block of options in between. Might be better to have all the direction options together at the bottom.
Mark Hughes
