When running tool path simulations on a single operation, the simulation is not recognizing that REST has been selected. I used to be able to run a simulation, say on operation 3 of 7, and it would start with all stock removed from previous tool paths. Now, unless I simulate all operations from the beginning, the stock reverts back to the original. I'm positive Fusion did not always do this.
Did I change some setting somewhere? TIA
Solved by seth.madore. Go to Solution.
It sounds to me that you have your In Process Stock calculation turned off. You can find it on the "Utilities" tab:
