This new update tonight has no ability to simulate tool path.
I have tried re booting since the update.
Nothing...
I believe there was something going on while I was programming that happened to be while the update was happening...
I ended up going through the tool paths and going to the Geometry tap and re generated the tool paths.
Then and only then would they show up...
I'm having this exact same issue. It's really frustrating because the work has been done. The program is an extremely complicated mold with 24 different 3d operations with lots of rest machining going on. It's going to take a couple of hours just to go through, re select, and re generate the toolpaths. What is causing this??
Sorry it took a while to reply, I had to get the previous project done. It happened again today though. I have attached the file. I had been working on this design all day, and was on the last operation that I needed. Went to simulate and got a "Failed to Import Toolpath" message.
It's the last toolpath in your file, it appears to have dropped it's selections:
