So one thing we can all agree on is there is plenty of confusion. What complicates matters is not all cutting tool suppliers use the same nomenclature.
What is additionally confusion is the need to handle a tool that starts at one diameter then gets larger. The reason tools change shape is for strength and reach. Why this is important is 1) you always want to cut with the portions of the tool appropriate to the cutters design AND that meets your programming needs. 2) It also means NOT hitting or rubbing or gouging with other parts of the tool.
So take Harvey Tool as an example I attached. A critical dimension is labeled "L3" and when you see it in the example it makes sense that you need to know what that value is so you don't try to cut deeper than this. otherwise you will gouge your part with the larger diameter that is not designed to cut.
So Harvey Tool refers to that "L3" label as "Overall Reach" and that makes sense. IF everyone called this "L3" dimension the same thing and everyone understood it's importance the confusion would disappear. I only advocate clarity and I hope this helps 🙂
One other key thing to note. The Harvey Tool Example is excellent to show what is referred to Diameter vs Reach. And for maximum rigidity and best machining finish you should select the shortest tool that will cut your part. So lets say you have a part with some micro slots. The dimension is [0.018" wide slot by 0.150" deep] there are many tools in that example below that can work.
But the one tool I would use is the 0.015" Diameter with the "L3" of 0.156". That tool has a 12x length to diameter ratio. It's not too bad. That tool will be the strongest and have the least flex. I've personally cut 30x diameter to length ratio and it requires much more tool path and a different strategy to get an accurate cut. So in all theses examples "Overall Reach" is actually a great name for this field as Harvey Tool elected to call it. Not saying Fusion has to do that. It just needs to have clarity so we know what we are doing and why 🙂
