Having an issue with the Siemens Mill-Turn post. If using the same tool for two different milling operations the tool will initially use G94 (feed/min) for the first operation but the second operation it resets back to G95 (feed/rev) on the machine with no visible sign of a G95 in the program. How can I change it that it forces a feed type (G94/G95) after every speed call?
