Fusion Manufacture
Post Process Error
7 REPLIES 7
Message 1 of 8
gmdimarzio88
364 Views, 7 Replies
Post Process Error
After updating I now get this error when posting my program. It doesnt make sense. The names are the same format.
7 REPLIES 7
Message 2 of 8
most likely your post was updated with fusion and any mods you made to allow for alphabet names like that have been removed.
Please click "Accept Solution" if what I wrote solved your issue!
Message 3 of 8
yh.bae
in reply to: gmdimarzio88
extension= "."; 이걸로 교체하면 해결됩니다. (Replacing it with this solves the problem.)
Message 4 of 8
Thank you for report, @gmdimarzio88 . We will take a look, how to fix the issue. This dialog was replaced recently, and seems its behaviour is not 100% compatible with what we had before. It does not allow you to save file without extension.
Viacheslav Shapilov
Developer Technical Services
Autodesk Developer Network
Message 5 of 8
Exactly. It used to just pull in the extension automatically. 🙂
Message 6 of 8
gmdimarzio88
in reply to: yh.bae
Unfortunately, this didnt work for me.
Message 7 of 8
We are going to fix the issue. But for now you can type-in extension manually as a workaround.
Viacheslav Shapilov
Message 8 of 8
gmdimarzio88
in reply to: yh.bae
