Hello everyone.
First time using a slitting saw - can anyone help me out with setting this one up? I was thinking 0.125" doc on this one. Part attached.
Any help is appreciated.
Solved by CNC_Lee. Go to Solution.
Solved by seth.madore. Go to Solution.
I made a few tests for you, attached for review.
It depends, I suppose. What is the tool material and what is the material being cut? Do you have a stout machine, or do you need to baby it thru the cut?
Hi Seth,
Material being cut is 1045 and 1018 mild steel. Tool material is HSS. Machine is a Mori Sieki NL3000y, so enough machine for the job i would say.
Yeah, the Mori is a stout machine. Personally, I would make an attempt at doing it in one shot (provided you've got a couple extra saws (just in case)
Also, if you're in the USA, both Harvey and Internal Tool make some carbide slitting saws in smaller diameters, you wouldn't need to go with a 4" HSS saw...
I only got the one 4" HSS saw for this job. So taking it easy this time would probably be the way to go.
Hmm. I'm never comfortable going into a job with only one tool at my disposal, but it's also easy for me to say as you're likely not the one making that judgement call.
I'd certainly reduce your feedrate. .001" per tooth is going to be quite aggressive. As an example, I run a 1.5" (12 teeth) saw in stainless at 600 RPM and 2.0 IPM. You're running at 57rpm and 2.0" IPM. I'd likely bump the speed up to 75sfpm and reduce the feed per tooth by about half. Depth of cut (in 3 passes) would be .150 per (although I think you could do this in one shot, just taking it slow and plenty of coolant)
ours has more like 100teeth so we do .0001 cpt, 3x thickness as DOC, and about 50-75sfm in stainless. Everything works out on size. There are some great guide PDF's online if you just look into them.
@seth.madoreI do buy my own tools but was unsure what will work best for me so I just got one unit to try for a quick job. Are your saws carbide or hss?
I will try with the suggested feeds and speeds, thanks for your input on this.
@programming2C78BI actually did try looking up online but couldn't find much.
Carbide, always carbide 🙂
(that's not entirely true, there are times when I have to use a gigantic milling arbor and .50" wide x 4" dia HSS saw)
It's not .0005 ipr, but IPT (inches per tooth). It should be about a 12 min cycle
(which is also why I would prefer carbide and a single pass)
Hi Seth,
I got the following error log when I try and output this code; can you tell me what this means?
@jeph_s22
The toolpath could be out of the machine travel linits as defined in the machine configuration. It is a bit haed to tell without the post processor.
