How can I cut this hole? It goes through the product.
Solved by leoE4H8W. Go to Solution.
Solved by programming2C78B. Go to Solution.
Solved by a.laasW8M6T. Go to Solution.
Solved by nubrandao. Go to Solution.
Hi I would drill the ends out then ramp down with 2d contour and an endmill.
Looking at that part you would need a longer than standard endmill, it will also depend on the material.
Best to use a relieved shank cutter like
This is the model, It doesn't cut the hole. I did it before but can't remember how I did it.
Hi
I cant really tell much about what's going on from just a picture. the Fusion File would be more helpful
You probably just need to select the contour you want to machine and turn on ramping in the Linking tab
Hi
Is this the 3rd time your posting the same issue? I answered you in the last one. Your depths are too shallow to include the feature in your toolpath.
Here's the file
Finally got it right using 3D contour. Thanks for your help.
