Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Rectangular Hole
8 REPLIES 8
Message 1 of 9
leoE4H8W
394 Views, 8 Replies
Rectangular Hole
leoE4H8W
How can I cut this hole? It goes through the product.Screenshot 2024-07-04 150242.png
Rectangular Hole
8 REPLIES 8
Message 2 of 9
a.laasW8M6T
in reply to: leoE4H8W
a.laasW8M6T
Hi I would drill the ends out then ramp down with 2d contour and an endmill.
Looking at that part you would need a longer than standard endmill, it will also depend on the material.
Best to use a relieved shank cutter like
Message 3 of 9
nubrandao
nubrandao
I would make a drill or two ,
Then countour 2d
Then countour 2d
Message 4 of 9
leoE4H8W
in reply to: a.laasW8M6T
leoE4H8W
This is the model, It doesn't cut the hole. I did it before but can't remember how I did it.Screenshot 2024-07-04 161316.png
Message 5 of 9
a.laasW8M6T
a.laasW8M6T
Hi
I cant really tell much about what's going on from just a picture. the Fusion File would be more helpful
You probably just need to select the contour you want to machine and turn on ramping in the Linking tab
Hi
Message 6 of 9
programming2C78B
programming2C78B
Is this the 3rd time your posting the same issue? I answered you in the last one. Your depths are too shallow to include the feature in your toolpath.
Please click "Accept Solution" if what I wrote solved your issue!
Message 7 of 9
leoE4H8W
leoE4H8W
Here's the file
Here's the file
Message 8 of 9
leoE4H8W
in reply to: programming2C78B
leoE4H8W
Tell which depths are too shallow, please.
Message 9 of 9
leoE4H8W
leoE4H8W
Finally got it right using 3D contour. Thanks for your help.
