Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Postprocessor for Heidenhain (espc iTNC530)
9 REPLIES 9
Message 1 of 10
911 Views, 9 Replies
Hi there
Is there a possibility to change the behaviour of the Heidenhain generic PP, so it uses the Tool names instead of Tool numbers?
Since this is a common option while using Heidenhain Systems.
Regards Sam
9 REPLIES 9
Message 2 of 10
ivan.stanojevic
Yes, there is. You can replace the "tool.number" variable with other variables inside your postprocessor.
If you postprocess your file with the dump postprocessor you can see all available parameters related to the tool.
For example, you can change this line:
writeBlock(
"TOOL CALL " + tool.number + SP + spindleAxisTable.lookup(spindleAxis) + conditional(!isProbeOperation(), " S" + rpmFormat.format(spindleSpeed))
with this:
writeBlock(
"TOOL CALL " + tool.vendor + SP + spindleAxisTable.lookup(spindleAxis) + conditional(!isProbeOperation(), " S" + rpmFormat.format(spindleSpeed))
etc.
Ivan Stanojevic
Message 3 of 10
Pretty sure it is in the generic Siemens as a post processor property.
So you can find it there.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 4 of 10
in reply to: ivan.stanojevic
writeBlock(
with this:
writeBlock(
etc.
Yes I did have a look at that, but was not able to find any documentation about, what methods (tool.number, tool.vendor) you could use. Tried it with tool.name wich apparently didn't work. So is .vendor the actual thing or just an example?
Message 5 of 10
Laurens-3DTechDraw
writeBlock(
with this:
writeBlock(
etc.
Pretty sure it is .description
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 6 of 10
ivan.stanojevic
@Anonymous
Please take a look here:
http://autode.sk/2syrhwQ
However, if you want to get the tool type instead of the listed above you need to use something like this:
getParameter("operation:tool_type")
Ivan Stanojevic
Message 7 of 10
dimikosto
i need a post processor for heindenhain itnc530 where can i download? please help
Message 8 of 10
marcus.toepke
in reply to: dimikosto
For normal use you can use the generic postprocessor from Autodesk library. Only if you wish special things you need a edited one.
https://cam.autodesk.com/hsmposts
Message 9 of 10
dimikosto
in reply to: marcus.toepke
thank you very much but how can i creat one?
Message 10 of 10
dimikosto
i have a itnc530 HEINDENHAIN machine i have 3 axis xyz machine with table rotation B extra
Technology Administrators
