Hello
Sorry if this has been asked hundreds of times but i m new to this.
We have an old (i don't have info on the exact model at hand) cnc Haco plasma cutter. i did not find a Haco post procesor on the list of post processors, so i m wondering if there is an open generic postprocessor for plasma cutter that will work with it. Or do i need a precise one for our plasma (means i need to ask Haco for one).
BR Miha
Likely not. I think this is the first request I've seen for such a machine. If you want to attach your successful post to a reply, any future users will be able to tap that
OK so here is the working Post for haco plasma. I added a couple lines of codes from different thread to cut holes and radius smaller than 20mm with half the speed. It could make the cut worst sometimes. Like outside radius on corners, slots,.. Some deformation appears when there is change in cut speed. There should definitely be a option in fusion for additional cutting speeds with automatic recognition of small holes and slots.
