hi group
every time i try to post the parting off cycle i get a "post failure" written on the end of the cam file and looking at the gcode it says see log but i cant find the log anywhere on the pc?
please advise
Solved by HughesTooling. Go to Solution.
Solved by safiredesignengineers. Go to Solution.
Fusion tends to delete the log before the editor can start, try starting the editor before you post or change the editor to notepad as it starts faster.
Mark
Mark Hughes
Owner, Hughes Tooling
Are you using the ProtoTrak post? If you are the problem is the Turret number for your last tool.
Mark
Mark Hughes
Hi Mark
I have fixed it i think, just checking now but it was to do with the tool. i copied a tool from the tormach range and edited it originally. but i just created one from new and it seems ok. 8-)
thanks for your input.
Just in case you run into this again all you need to do is edit the tool and change the turret to zero.
Mark
Mark Hughes
