Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Post falure cant find log either
5 REPLIES 5
safiredesignengineers
401 Views, 5 Replies
hi group
every time i try to post the parting off cycle i get a "post failure" written on the end of the cam file and looking at the gcode it says see log but i cant find the log anywhere on the pc?
please advise
5 REPLIES 5
Fusion tends to delete the log before the editor can start, try starting the editor before you post or change the editor to notepad as it starts faster.
Mark
Mark Hughes
Owner, Hughes Tooling
Are you using the ProtoTrak post? If you are the problem is the Turret number for your last tool.
Mark
Mark Hughes
Hi Mark
I have fixed it i think, just checking now but it was to do with the tool.  i copied a tool from the tormach range and edited it originally. but i just created one from new and it seems ok. 8-)
thanks for your input.
Just in case you run into this again all you need to do is edit the tool and change the turret to zero.
Mark
Mark Hughes
thanks mark 🙂
