Fusion Manufacture
Post Bug: Part transfer with cutoff does not turn spindle on cutoff operation DMG Mori NLX Mill/Turn post
1 REPLY 1
jrushTUQ3U
118 Views, 1 Reply
Using the latest DMG Mori NLX Mill/Turn post version 44132, when doing a subspindle grab then a parting operation the resulting gcode for the parting operation does not turn on the spindle.
This can be tested with the Cam Samples>Post Processor>Stock transfer project. Select the "Part transfer with cutoff" setup right click, create nc program and pick the DMG Mori NLX Mill/Turn post.
Code without G96 from 44132 post:
(SUBSPINDLE GRAB)
G330
G28 U0. V0.
G30 W0.
M05
M09
M01
M69
G28 H0.
G98 G18 M46
M246
M211 (UNCLAMP SUB CHUCK)
G04 U1
M51 (CLEAN OUT CHIPS)
M251
G04 U5.5
M59
M259
G00 B0.
G38 B-0.85 K0. F40. Q0.01
M210 (CLAMP SUB SPINDLE)
G04 U1
(PART1)
G99
G00 Z0.2953
X1.8 Y0.
Z-1.0734
G01 X-0.1969 F0.005
X1.8
G00 Z0.2953
G28 U0 M09
M80 (CONFIRM CUTOFF)
G04 U0.5
Code posted with older post (44113):
(SUBSPINDLE GRAB)
G330
G28 U0. V0.
G30 W0.
M05
M09
M01
M69
G28 H0.
G98 G18 M46
M246
G04 U1
M251
G04 U5.5
M59
M259
G00 B0.
G38 B-0.85 K0.006 F40. Q0.01
G04 U1
(PART1)
G99
G00 Z0.2953
X1.8 Y0.
G96 S300 M03
Z-1.0734
G01 X-0.1969 F0.005
X1.8
G00 Z0.2953
G28 U0 M09
G04 U0.5
1 REPLY 1
jrushTUQ3U
in reply to: jrushTUQ3U
Also..
If you do a subspindle grab, setting up for a bar pull in a setup configured for the secondary spindle it unclamps the main chuck instead of the subspindle chuck before doing a grab. Dropping the stock and leaving the sub chuck clamped.
Trying to work around this I setup a 3rd setup configured for the primary spindle and moved the grab, bar pull and return operations in that setup. This does clamp/unclamp the correct chucks but does not call a G54 for the new setup, also potentially crashing the subspindle.
