Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
plunges and exits too close to stock
2 REPLIES 2
magpiemachining
196 Views, 2 Replies
this may not go to the right board as this seems to not  be behaving correct either. tool 35 center pocket, plunges too close to stock. no exit  or entry will work. Used pre drill and cutter plunges into stock then ramps so that is not an option either. with no pre dill,  at the end of the path the tool lifts while engaged with stock. it may look right on the simulation but the code is wrong,
2 REPLIES 2
engineguy
in reply to: magpiemachining
@magpiemachining
This look anything like what you want ?? If yes then try attached file 🙂
magpiemachining
in reply to: engineguy
I was able to get the lead out to work which was the real problem banging on the wall as et rapid out.. you got the lead in to work.  I changed  the ramp step to get it to work. looks like you changed it back and expanded the dialogue and I still cant figure why it needed that to happen.  thanx for taking a look at it
