Fusion Manufacture
Optimisation and errors on a Topographical model
2 REPLIES 2
284 Views, 2 Replies
Hi All,
So I am trying to cut out a topographical model from a lump of wood. Unfortunately I have been having some problems. First the program tells me that there are collisions between the bit and the stock. How can I tell the program that it should just cut through the stock (ie that it is not a collision)?
Secondly, when I made some changes (cant remember what exactly), it will not generate a toolpath. I have no idea why it cannot generate the toolpath. Can someone please advise me on this?
Third, is there any way to optimise the toolpaths that I have in the file?
Many thanks for any help you can provide.
2 REPLIES 2
LibertyMachine
Change your Adaptive selection to "None" or Silhouette instead of selections.
Use 3D Morph instead of parallel. Using the same step over and speeds/feeds I got a half hour cycle rather than the 2 hr cycle you had
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
in reply to: LibertyMachine
Thanks LibertyMachine, that is very helpful with the optimisation cycle.
But how can I get the code to stop telling me that there is a clash every
time it touches the stock to cut the part? Even when I have it
on silhouette there are at least 100 'collisions' between the bit and the
stock where it drives in to start cutting. I dont mind if it cuts more of
the stock but I dont want it to break a bit. Shoud I extend the outside
cutting boundary or something similar?
Technology Administrators
