Hi All,
So I am trying to cut out a topographical model from a lump of wood. Unfortunately I have been having some problems. First the program tells me that there are collisions between the bit and the stock. How can I tell the program that it should just cut through the stock (ie that it is not a collision)?
Secondly, when I made some changes (cant remember what exactly), it will not generate a toolpath. I have no idea why it cannot generate the toolpath. Can someone please advise me on this?
Third, is there any way to optimise the toolpaths that I have in the file?
Many thanks for any help you can provide.
Change your Adaptive selection to "None" or Silhouette instead of selections.
Use 3D Morph instead of parallel. Using the same step over and speeds/feeds I got a half hour cycle rather than the 2 hr cycle you had
