I've had this happen twice now to me. I can't reliably reproduce it but both times I was doing something along the lines of:
Just realized that the CAM operations that I'd added since the last save are now gone.
Edit: nevermind, I'm blind
Something like this happens all the time to me. I go into the cam environmen, and there are no operations there. exit document (don't seem to have to actually exit fusion program though) reopen and they are back.
I cannot reproduce this issue on my side, either. Can you please help share one of your models with us? Click the Export command under the File command and then save it as a .f3d file, please. Or you can invite Debbie.Lou@autodesk.com to your project if possible.
BTW, can you please let us know how did you install Fusion 360? Which OS and graphics card are you using now? Thanks for your support.
I had this happen once too. It only happpend once and I can't even remember now which file it was or exactly what I was doing when it happened. I do remember I had switched back and forth between modelling and CAM a few times, and at one point I switched back to CAM and there were no operations or setups in the tree. It was like they just vanished. To recover I think I just closed the file without saving and then opened it again. I wish I could remember more bit this was probably 2-3 weeks ago.
C|
Just to prove I'm not crazy!
a screen cast of my cam operations disappearing and magically reappearing
https://screencast.autodesk.com/main/details/8e6bf438-707b-4889-a29b-28c1df02733c
edit-I just noticed that I had accidentally deleted a body that was referenced in an operation, could that have something to do with it?
I had been working on the model for a while. I just added an edit to reply from a few min ago, which was-
I just re-read your question. I had been wot=rking on the model for a little while, but that was the first time that session that I opened the cam browser.
@laughingcreek wrote:I had been working on the model for a while. I just added an edit to reply from a few min ago, which was-
I think it might be related to deleting a body like you say. I've seen some odd behavior after deleting a body, where the tool paths with be flagged as needing regeneration (correct), but will regenerate as if nothing was wrong, even though they are referencing something that doens't exist anymore (not correct). The tool path may or may not be the same as before, depending on where the geometry was referenced from. For example, selections for avoid/touch surfaces just vanish, while model geometry selections seem to persist. To me it's not really clear if this is a bug or not, because normally you wouldn't want to use operations where the referenced model was deleted.
C|
Can you confirm if the issue is only for the specific case where you leave the Model selection empty for the Setup (which is currently ok)? Thanks. Or do you have issues in cases where you have selected geometry explicitly.
All my setups have models selected. I aso often select specific chains using the "Selection" mode for "Machining Boundry" to control which areas are machined.
@fonsecr wrote:Can you confirm if the issue is only for the specific case where you leave the Model selection empty for the Setup (which is currently ok)? Thanks. Or do you have issues in cases where you have selected geometry explicitly.
That's a good question, and I'm not actually sure. Here's a link to the file I was having issues with.
https://myhub.autodesk360.com/ue29ef632/xdio/permalink/XD919a0QTf3c32634dcf2efe96da85bdbe8a
The thing about this file is that it was copied from another project where it has a long and convoluted history of edits, and at this point I can't be sure what is what anymore. The operations marked "WRONG" were the ones that were having issues. It might be possible to go through the timeline and reconstruct what happened.
C|
Thanks for the feedback. Please help invite Debbie.Lou@autodesk.com and Rene.Fonseca@autodesk.com to your project in case we can get your shared model. Thank you.
