Fusion Manufacture
operation - parallel
27 REPLIES 27
Message 1 of 28
2580 Views, 27 Replies
Hi
I have a questions. In my toolpath file I put the parallel operation. The geometry which is operated is the part of the plastic injection mold. What parameter controls the course of the optimization path  for unnecessary runs - those  runs which are shown in attached image? This is the beginning of the path, and then the tool enters deeper into the stock and after all is OK.
Ludwika
27 REPLIES 27
Message 21 of 28
in reply to: jeff.walters
Hi Jeff
Sorry but the warning applies to other operation - pencil which at this point is skipped. For operation parallel with undiscovered errors, the log file is clean. The ribbon simulation is clean also - there are no red flags. Please take a look at the attached picture.
Message 22 of 28
jeff.walters
this isnt the operation your running?
Jeff Walters
Senior Support Engineer, CAM
Message 23 of 28
bobvdd
For the parallel operation, I need to look into the areas thatyou circled in red. Looks like the tool is diving needlessly too deep in the material
For the pencil operation, the error in the log and the yellow exclamation mark seems justified as you really don't have any internal corners or fillets to clean-up. Maybe you were after something like the Trace operation?
Bob
Bob Van der Donck
Principal UX designer DMG group
Message 24 of 28
in reply to: bobvdd
Unfortunately, all what we wrote is based on the simulation ,in real conditions it can be different. Perhaps the area in these places is so displayed - where the cutter enter straight down. Why?
In the soft material (PVC, PE hard, PP) is allowed to enter the cutter straight down but rather never in hard materials. The cutter should go beyond the material, leave with stepdown and back to the horizontal milling.For this procedure would be the best  Tool outside boundary option with additional offset, but unfortunately it is the application gives a strange path. What we saw earlier.
It is a pity that I can not test this path in real.
Message 25 of 28
bobvdd
The simulation is pretty accurate and pretty close to what you would get on the machine.
But indeed the simulation is telling us that the tool is cutting in the material during the transition from one cutting pass to the next (the green portions of the toolpath).
To avoid these troublesome transitions , you could use the "One way" option on the Passes tab in the dialog. I saved a new version  in your project with this option set.
Have a look to see if you like it better.
Here is how it looks like during simulation:
Bob Van der Donck
Message 26 of 28
in reply to: bobvdd
Hi Bob
I have earlier tested one way option with changed Vertical Lead-in radius and Vertical Lead out radius -greater than cutter's diameter The results are satisfactory and your reply convinces me that this is riht way.
Thanks Bob
Message 27 of 28
in reply to: bobvdd
Hi Bob
I have finished my toolpaths. I have made two parallel operations -first is the roughing mill with the Bull-nose Mill and second is the final mill with the Ball Mill. The chamfers on the edges after fist operation do not affect the end result because ball mill smoothes them. So I think the problem is solved.
Thanks for your support and until next time.
Ludwika
Message 28 of 28
bobvdd
Hi Ludwika,
Great to hear that you could come to a satisfactory solution. Looks like the ball mill nicely cleaned up what the bull-nose mill had left behind.
Keep those new projects coming:-)
Bob
Bob Van der Donck
Technology Administrators
