I would like to remove this from my post
var tools = getToolTable();
if (tools.getNumberOfTools() > 0) {
for (var i = 0; i < tools.getNumberOfTools(); ++i) {
var tool = tools.getTool(i);
var comment = "T" + toolFormat.format(tool.number) + " " +
"D=" + xyzFormat.format(tool.diameter) + " " +
localize("CR") + "=" + xyzFormat.format(tool.cornerRadius);
if ((tool.taperAngle > 0) && (tool.taperAngle < Math.PI)) {
comment += " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg");
if (zRanges[tool.number]) {
comment += " - " + localize("ZMIN") + "=" + xyzFormat.format(zRanges[tool.number].getMinimum());
comment += " - " + tool.description;
writeComment(comment);
If I / it out Fusion says the post is invalid. I do not want to see CR or Taper as it takes up valuable info the line.
Solved by GeorgeRoberts. Go to Solution.
I’m not at my computer to test, but this should work
"D=" + xyzFormat.format(tool.diameter) + " ";
George Roberts
Manufacturing Product managerThank you, that works. I didn't catch the "+" in line 6 that had to also be removed for it to work. I just copy pasted yours
Would you also be able to advise how to do so for my lathe post?
var compensationOffset = tool.isTurningTool() ? tool.compensationOffset : tool.lengthOffset;
var comment = "T" + toolFormat.format(tool.number * 100 + compensationOffset % 100) + " " +
(tool.diameter != 0 ? "D=" + spatialFormat.format(tool.diameter) + " " : "") +
(tool.isTurningTool() ? localize("NR") + "=" +spatialFormat.format(tool.noseRadius) : localize("CR") + "=" + spatialFormat.format(tool.cornerRadius)) +
(tool.taperAngle > 0 && (tool.taperAngle < Math.PI) ? " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg") : "") +
(zRanges[tool.number] ? " - " + localize("ZMIN") + "=" + spatialFormat.format(zRanges[tool.number].getMinimum()) : "") +
" - " + localize(getToolTypeName(tool.type));
comment += " -/- " + tool.description;
