Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
omit from posting
3 REPLIES 3
programming2C78B
174 Views, 3 Replies
omit from posting
I would like to remove this from my post
var tools = getToolTable();
if (tools.getNumberOfTools() > 0) {
for (var i = 0; i < tools.getNumberOfTools(); ++i) {
var tool = tools.getTool(i);
var comment = "T" + toolFormat.format(tool.number) + " " +
"D=" + xyzFormat.format(tool.diameter) + " " +
localize("CR") + "=" + xyzFormat.format(tool.cornerRadius);
if ((tool.taperAngle > 0) && (tool.taperAngle < Math.PI)) {
comment += " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg");
if (zRanges[tool.number]) {
comment += " - " + localize("ZMIN") + "=" + xyzFormat.format(zRanges[tool.number].getMinimum());
comment += " - " + tool.description;
writeComment(comment);
If I / it out Fusion says the post is invalid. I do not want to see CR or Taper as it takes up valuable info the line.
Please click "Accept Solution" if what I wrote solved your issue!
3 REPLIES 3
I’m not at my computer to test, but this should work
"D=" + xyzFormat.format(tool.diameter) + " ";
George Roberts
Manufacturing Product manager
If you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
Thank you, that works. I didn't catch the "+" in line 6 that had to also be removed for it to work. I just copy pasted yours
Would you also be able to advise how to do so for my lathe post?
var compensationOffset = tool.isTurningTool() ? tool.compensationOffset : tool.lengthOffset;
var comment = "T" + toolFormat.format(tool.number * 100 + compensationOffset % 100) + " " +
(tool.diameter != 0 ? "D=" + spatialFormat.format(tool.diameter) + " " : "") +
(tool.isTurningTool() ? localize("NR") + "=" +spatialFormat.format(tool.noseRadius) : localize("CR") + "=" + spatialFormat.format(tool.cornerRadius)) +
(tool.taperAngle > 0 && (tool.taperAngle < Math.PI) ? " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg") : "") +
(zRanges[tool.number] ? " - " + localize("ZMIN") + "=" + spatialFormat.format(zRanges[tool.number].getMinimum()) : "") +
" - " + localize(getToolTypeName(tool.type));
comment += " -/- " + tool.description;
