I know it's currently a preview, but I don't really like the new library.
Old library gave us a sorted list (by tool number), with tool type (image), number, dia , type, description.
New library, god knows what the sort is, number, dia, shoulder length(!), description. Doesn't really flow to the eye, difficult to parse. Was the world crying out for shoulder length in the description? If you must have something wouldn't flute length be better (actually, just leave it blank).
Where are all the selectable columns from the old library?
Doesn't look like you can select multiple libraries.
Did Add Tool have a blow to the head and forget about form tools?
It's...so...slow......Seriously, it's like every click has a 1 second lag.
The old cutter geometry drawing was nice and readable. The new one you have to click on the fields to highlight what the size is.
Multiple feeds and speeds will be a welcome addition, I'm not testing it on a production job though.
Suggestions:-
How about being able to modify the coolant and break control settings from the info tab rather than editing the tool? And a bulk edit tool similar to compare and edit in toolpaths? Would be useful for setting multiple tools with similar cutting data in one hit.
Obviously, sorting and multiple library selection.
Can a default holder be set per library? Annoying when you're working on a mixture of BT40 & BT50 machines and think your tool holders will clear. Even more annoying when you have to edit a couple of dozen tools after the fact.
Similarly, can we set a default tool library in the machine configurations?
When editing holder or shank geometry, can you number balloon the geometry in the generated sketch. Would make it much easier to parse the sizes.
Whatever happened to sub-folders/libraries? I thought some progress was made on this months ago?
