Fusion Manufacture
Nesting Reports Low Resolution Issue
4 REPLIES 4
jacobXNNNF
117 Views, 4 Replies
I'm trying to create nesting reports for use by operators to know which parts to label properly. However, the nesting reports images of the sheets and the part names are horribly low resolution. I've seen some people mention this before and no fix has ever been added. Is there any way around this? Makes the reports only useful from an analysis point of view and not really helpful for operators. Attached is an excerpt from a report that shows this issue.
4 REPLIES 4
Is the screenshot you have shown from the report preview (in Fusion) or from the pdf that was saved on local drive?
It was not a screenshot. I just pulled this specific page from the Default Report and only am showing that page. This is the exact PDF that would get saved to a local drive.
When the report is opened could you please try to go to print in right upper corner and print this report to pdf and save it to local drive? Sometimes it has better resolution so I believe it can look a little better.Screenshot 2024-08-22 at 14.07.41.png
The PDF that is attached to my original post was exported in that exact same manner. I just cut it down to one page to showcase the issue I'm having. No matter how I try and export the PDF the end result is a very pixelated and grainy image as others have encountered before.
