Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Fusion Manufacture
Need help with machining open area
2 REPLIES 2
PetePayne
259 Views, 2 Replies
Hello, I have this part I am trying to machine out of 2"x2" 6061 square.
The area of the part on the bottom right corner need to be cut all the way out of the stock.
But I can not figure out what option to use. Would this be best done with the 2D adaptive clearing or 3D adaptive clearing?
I guess that because there is no geometry there is why I am having trouble getting it cut out.
Thanks for all the help!
2 REPLIES 2
Steinwerks
in reply to: PetePayne
To get this geometry correctly you'll need to turn the part on its side, so I'd suggest creating a second setup to do just that. In your 2D Adaptive you should also turn on Stock Contours on the Passes tab so it will take into account all of the stock as defined in the Setup.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
PetePayne
in reply to: Steinwerks
Thanks Steinworks!
I will give that a try right now.
