Fusion Manufacture
Need help editing 840D post processor to use TRANSMIT function.
0 REPLIES 0
Message 1 of 1
kuhnjst
129 Views, 0 Replies
Hi everyone this is the post in question ctx POST 2.cps
When i post the code to our DMG CTX beta mill/turn lathe, I get the error message: SP4 not defined or option/function not activated.
So I have it somewhat working correctly. I've modified the post to use C4 instead of SP4 transmit function. It works with the way I have it modified but... it feeds in degrees per minute and if I have an angular adjustable 90 degree head loaded, it doesn't post out correctly. Any suggestions to fix this correctly?
; %_N_1001_MPF
; T="9MM ID BAR" NR=0.2 - ZMIN=8.7 - boring turning
; T="17.7 X 3MM SLOT CUTTER" D=17.7 CR=0.2 - ZMIN=52.8 - slot mill
WORKPIECE(,,,"CYLINDER",192,58.3,-13.4,-12.4,164.7)
G94 G18
G71
LIMS=4000
M96
G53 G0 X500 D0
G53 Y0 D0
G53 Z500 D0
MSG ("; 2D Contour3")
TC(1)
DIAMOF
SETMS(1)
G97 S1=2500 M1=3
G17 G90 G94
G54
G0 Y0
SP4=0.
TRANSMIT(4)
M108
G0 Z73.3
X68.3 Y1.8
Z63.3
G1 Z59.3 F150
Z54.8
G2 X68.3 Y0 Z53 CR=1.8 F250
G1 Y-1.8
G3 X70.1 Y0 Z53 CR=1.8
X0 Y70.1 Z53 CR=70.1
X-70.1 Y0 Z53 CR=70.1
X0 Y-70.1 Z53 CR=70.1
X70.1 Y0 Z53 CR=70.1
X68.3 Y1.8 Z53 CR=1.8
G1 Y0
G2 X68.3 Y-1.8 Z54.8 CR=1.8
G0 Z73.3
TRAFOOF
DIAMON
0 REPLIES 0
