Hi everyone this is the post in question ctx POST 2.cps
When i post the code to our DMG CTX beta mill/turn lathe, I get the error message: SP4 not defined or option/function not activated.
So I have it somewhat working correctly. I've modified the post to use C4 instead of SP4 transmit function. It works with the way I have it modified but... it feeds in degrees per minute and if I have an angular adjustable 90 degree head loaded, it doesn't post out correctly. Any suggestions to fix this correctly?
