Fusion Manufacture
Need a line font for engraving
6 REPLIES 6
fishtruk
2995 Views, 6 Replies
Hi, when I put text on a surface I've been using a font for nice pretty text.
I don't need that all the time.  Is there a special font for simple engraving text fast and dirty? Or am I barking up the wrong tree?
Nelson
6 REPLIES 6
fishtruk
in reply to: fishtruk
Is it simplex.shx?  I'll try.
LibertyMachine
Yes, it is!
But, all you need to do is create the text. No exploding it. Just select the bounding box when you want to do your engraving.
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
fishtruk
in reply to: LibertyMachine
Do I have to use simplex?  Will it engrave down the middle of any font selected?
(because I already put the text on and I'm lazy)
LibertyMachine
I omitted one detail;
For single line fonts (Simplex and others in that area), use the Trace operation with an Axial Offset.
Engrave is likely not going to work, as it's looking for width and depth
Seth Madore
fishtruk
Thanks a lot!  It does seem to work, depth control does the trick. It just offsets in from the outside boundary of characters giving a double line.  I'll use the simplex. I'll have to resize it, lazy, but I can handle it!
fishtruk
Thanks Seth,
Lookin good.  Trace - axial offset is a little unintuitive - could have been on the Heights dropdown but your clue did it!
Technology Administrators
