- Mute
- Permalink
- Report
I have multiple pockets with the same size and depth (counterboards) and would like to pocket them in one 2D operation.
If I select all in one operation, it would be programmed to perform the first pass then jump to the next pocket and the next until it comes back to the first pocket for the second pass.
If I select one pocket per operation, it takes the first pass then retracts then the second pass.
The passes I refer to is due to multiple pass option of 1mm where the pocket depth is 2mm.
What do I select so that if multiple pockets are selected, the tool finishes with the first pocket completely before moving to the next?
