3D Contour Bug.
3D Contour Bug.
HughesTooling
Consultant Consultant
3D Contour Bug.
HughesTooling
Noticed an odd bug with the attached file. If you set the boundary to tool inside you get multiple passes a each level, setting tool centre on boundary works as expected.
If you simulate the attached file you'll notice it goes around the pocket about 15 times at each level!
Mark
Mark Hughes
Owner, Hughes Tooling
Chetan.Bankar
Hi @HughesTooling,
Thanks for raising your query onto Autodesk Fusion 360 forum.
I was able to replicate this unwanted behavior and had reported this to development team. Reference: CAM-13926
As you mentioned if we use the Tool Containment as Tool centre on Boundary or if we change the tolerance of the toolpath then we don't get this unwanted behavior.
I will update you on the progress on this.
Thanks for your time and co-operation.
Chetan Bankar
Global Product Support
Submitting & Viewing Support Requests | Web Support | Phone Support
