Multiple pockets in one 2D Adaptive operation
jparamo4546
jparamo4546
I have multiple pockets with the same size and depth (counterboards) and would like to pocket them in one 2D operation.
If I select all in one operation, it would be programmed to perform the first pass then jump to the next pocket and the next until it comes back to the first pocket for the second pass.
If I select one pocket per operation, it takes the first pass then retracts then the second pass.
The passes I refer to is due to multiple pass option of 1mm where the pocket depth is 2mm.
What do I select so that if multiple pockets are selected, the tool finishes with the first pocket completely before moving to the next?
johnswetz1982
Try programming for just one pocket and place that operation into a [Pattern] Folder and create a liner or circular pattern from that.
daniel_lyall
Untick order by depth, doing this it should do one hole at a time.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
jparamo4546
Order by area did the trick
Even when i tick order by area and untick order by depth, unless i go full DOC of the pocket my tool still moves pockets after cutting the level . This causes the tool to rapid move alot more then required . Any thoughts?
daniel_lyall
Can you post the model with this problem?  To attach a file Go to File -> Export and save as a .F3D Archive File and attach it to your next post, if you can not post the file you can PM it to me or say in your next post you can not post the file and one of the Guys that do NDA work will help.
Daniel Lyall
The Big Boss
Mach3 User
