Minimum Z gone from setup sheet when using rotary
05:17 AM
- Mute
- Permalink
- Report
Good day!
I have encountered an error that my Setup sheet MIN Z disappears only when (any of) my setup operation contains Tool orientatated WCS.
If I create a setup with any number of operations, not using "Tool Orientation" from the operation properties, the setup sheet posts properly with MIN Z values visible.
If my setup contains even one operation that uses "Tool Orientation" to tilt my workpiece, the MIN Z paragraph disappears or shows zero (0) of value depending on how I generate the setup sheet.
Is there any way around this? Min Z is extremely useful to have when setting up tools.
Regards
Ahola KT
Link copied
