Rectangle bar 1.4 inch wide and cutting down to 1.25 inch and shaving the ends
Simulation works fine showing both sides cutting equally.
After posting G code air cut leaves one side untouched and takes .15 off the other side as opposed to .075 on each side.
Setup- stock is relative size and Y axis is offset to .075 per side.
2d contour geometry -selection closed chain
stock contours closed chain for boundary selected
Unable to find solution on forums. Any suggestions would be helpful and appreciated.
Judge
Solved by a.laasW8M6T. Go to Solution.
Hi
Where is your WCS defined, and where are you probing in the machine?
its possible you are using Model box point and the probing the edge of the stock as 0?
If you can share your file here we can provide further Diagnosis
Goto File>Export>Save as .f3d/.f3z
@j1
Welcome to the Community! I have moved your post here for greater visibility with the Manufacturing experts. Good luck!
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Yes WCS is set to Model box point and Model orientation and probing stock at edge as zero. Not clear why this is wrong. Have attached the file.
Thank you,
Judge
That does explain the problem,
If you have probed the STOCK edge as X0,Y0 then it will be offset as the WCS is set to the MODEL edge, you would need to probe the stock as X-0.0125 and Y-0.075 in the machine.
If you want to probe the STOCK edge as X0,Y0 then you need to set the Origin to Stock Box point instead.
Model box point:
Stock Box point:
Also its not great practice to use Model orientation for the Orientation, It may work in this case but its better to explicitly call out the Z and X axes with selections
Also may be worth Going through the self paced learning on NC programs, I see you have a large amount of them in your Browser where you should only have one.
https://help.autodesk.com/view/fusion360/ENU/courses/AP-NC-PROGRAM
Hope that helps explain the problem
