Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Machining a partial chamfer help
4 REPLIES 4
lukexm2
508 Views, 4 Replies
Hi guys,
I am seeking help programming the right tool-path for machining the highlighted blue surfaces on this part. I have not been able to get a strategy to work, if anyone can please point me in the right direct that would be great. I was intending on using a 6mm ball endmill to create the feature.
Appreciate any help.
Cheers
Luke
Tags (3)
4 REPLIES 4
Steinwerks
in reply to: lukexm2
Try changing reducing the stepover to something at least as small as 10% of the cutter diameter (default is 50% which is far too large for surfacing toolpaths). You may also want to change the Pass Direction on the Passes tab 90° from what it is now, but this is mostly an aesthetic requirement determined by the surface finish goal.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
heres a quick example part i made. hope this helps
lukexm2
Thank you guys for the help!
It would be great to be able to have the chamfer end mill do this in one/two passes. I might add it to the idea-station
Steinwerks
You can. Try 3D Contour with a matching Chamfer Mill.
Edit: well, it used to work. Maybe not so much now:
Neal Stein
Find me on:
