Fusion Manufacture
Machine Simulation for 3+2 axis head head amis
0 REPLIES 0
Message 1 of 1
dcsDHNS6
134 Views, 0 Replies
Good day, I've encountered the following problem with the Machine simulation:
It's a Head Head 5 axis machine.(CA) where the Y axis is the Long axis and the X axis is the one holding the Z.
C is around the Z axis 360°+/-. and A is 130/-130 around the X axis.
First of all. Despite the bad simulation, all the machining works perfectly fine.
The Simulation with the Machine, works fine for 5 axis simultan operations. For example this Flow operations show the movements correctly and it also exports the code correctly.
BUT now we get to the problem:
If i make a simple plate, which i want do drill on all 4 sides. it looks like this:
 Or something like that. But whatever i do. it does not show me what i want.
Now i tried all possibilities for the Tool orientation option, using X and Y on all possible sides and also flipping them.
But some sides just do not want to orient correctly.
Like i said, even though the simulation is not usable. The code was tested on the machine, and everything was machined fine.
I'd add some files. but they can easily be replicated.
Thank you in advance for your thoughts.
0 REPLIES 0
