Machine configuration not affecting time CNC mill time estimation
I recently noticed that my machine configuration does not seem to affect the estimated machining time. Doesn't matter if the Feedrate ratio is 10% or 1000%, the end result is the same. Same goes for tool change time. What could be causing this? I have two setups in the program and there is a single (same) machine used in both setups and to post the NC code. I changed the settings and posted the program again - same result.
We have different machines with different speed capabilities and it would be nice to be able to fine-tune the machine configs to match real machining times to estimated times as close as possible. This program takes 16.5min in reality while the estimation shows a bit over 14mins. Surely if tool change times were applied it would be much closer.
Fusion also seems to estimate 0secs for a threading operation that threads 6x M8 holes, which is weird.
Any ideas?
