Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Machine collison setting
1 REPLY 1
Bnuno608
150 Views, 1 Reply
hi, in my machine, i setup the machine, in colision kinematics, i enable everything, but maybe i enable  something i shoulnd maybe. the machine is getting collision signal
what collision should i disable? thanks in advance
1 REPLY 1
a.laasW8M6T
in reply to: Bnuno608
Hi
Its hard to tell exactly but its probably a collision between Z and Static(Z and Base)
You should go through the collision settings and determine which things potentially can collide and only turn on checking for those items
Like in your case X and Y cannot collide with the A ,C,Z or Table so you would turn of checking for those items against each other
Technology Administrators
