Hello: Can I use Fusion 360 to design and generate g-code and send the code to my machine and run that code using Mach3?
thanks
Javier
Solved by curtis.chan. Go to Solution.
To get the attachment removed click the Options on that post and select Report and ask admin to remove the file.
Mark
Mark Hughes
Owner, Hughes Tooling
I know that ....im sorry im just got a possible contract from a American Retailer.....
But i know you are very friendly of course....
But might others can copy that.....
Im having trouble make the File:
1.tap to go here......
Change the extension from tap to txt, another open for blocked file types is to ZIP them.
Mark
Mark Hughes
