Turning retract speed
joe
joe
I am making several grooving cuts at 0.1 ftpm for a depth of .200in. how do I set the retract speed so that between cuts the tool retracts at 5 ftpm instead of 0.1 ftpm?
jeff.walters
Sorry to say we don’t have that control in the system just yet. It has been suggested on ticket CAM-2366. The only option currently is to edit in the feed change.
Jeff Walters
Senior Support Engineer, CAM
Lonnie.Cady
You could rapid back up out of groove if you set your safe distance to zero.
joe
I edited the code and it works fine.
